John_Doe
- May 5, 2011
- C32
Well I have a coolant leak, a bad coolant leak lol. I haven't had a chance to even look underneath yet but I thought I would get a few suggestions beforehand.
So I keep losing coolant fluid but it usually only needs a top up every few weeks. The car has been off the road for about 2months so driving it today I noticed the coolant message pop up. I thought I would top up when I got to my work but I had to pick someone up first. While waiting I heard rushing water behind the dash so I turned down the stereo to listen properly and it sounded like it was flushing through. I looked under the car and found water dripping and a puddle with antifreeze present. Had a little look under the bonnet at the time but could only see a little bit of water on the front under the rad. I drove it straight to a petrol station to fill it up and it was empty. I drove it about 4 miles home fairly quickly and it was empty again when I got home.
The interior is fine, no water inside.
She has been running a bit funny for a while and I don't think its anything to do with this problem but shall explain briefly just in case. I have the fierce gear change from 1st to 2nd, tried to work this out before but all searches just bring back "live with it". Star Diag doesn't bring up any faults about it and a mechanic reset it to test but still does it. Autobox fluid level was fine last time tested. So I feel she don't run right, bit hesitant, lumpy, and obviously the gear changes.
