Hi , coolant warning came on today... checked coolant and was low so topped up.
Noticed small patch on drive , but no where near rad ... then noticed plastic skid pan under car had residue drips at very rear so assume coolant running here before onto ground.
Read some threads on here .. ran engine to pressurise system and then notice steam coming from large approx. 2" hose at bottom left of rad (when looking into engine bay from front of car ) so I assume leakage is also from here....
Glad its not rad or pump as experienced elsewhere .. should I use Radweld to seal this or anyone estimate cost of repair?? steam escaping from actual joint .. is there a seal here ?
metal spring clip holds hose in place .. hose faulty ??
Thanks in advance ....
Gaz
Gaz
