Correct tyre pressures please
garystu1965
Lytham St Annes
Mercedes E350 CDI Coupe
C270 CDI. Fronts 225/45/R17, Rear 245/40/R17. Currently they are set to 28.5 psi at back and 30.5 psi at front. Anyone know what min/max figures are ? I've looked everywhere for info to no avail.
Tyre Pressurs
Should be on inside of fuel filler flap.
David b is right. Those pressures seem a bit low, I'd have guessed 32 front 34 back.
30 psi fronts, 33 psi rears
It is in the fuel filler flap as mentioned by david b
Great. Cheers lads. I thought they were a bit low as well.
Are you sure the psi's refer to the 17" wheels in the sport pack though ?
They don't mention the wheel size on the filler cap. It may refer to the 16" standard wheels.
yup, that's what i've set my tires at. Ive also got the sports pack on my car
Does it matter what wheels you have?
