350_Coupe
ok, had my car a few days, still finding stuff out and generally feeling my way through things, and i have a couple of questions.
First - To do with back lighting, or label illumination
On the light switch panel on the right hand side, this one....
when the lights are on the mirror labels light up as does the light bulb and marker on the dial switch, but what does not light up on mine are the labels around the dial, if i turn it to main lights and turn pull the switch out to put on the fog lights, the 2 small fog light symbols are lit..... but at all stages the ring of labels around the dial switch are not lit.
is this normal ? seems to me like they should all be back lit.
Second - it seems the top 3 bars on the rear screen heater/demister are not working, is this a common thing, has anyone seen this before ? or is there maybe a lower setting that does not put all of the heating bars on ??
sorry if these seem daft questions, the labels around the light switch seem no different to the mirror labels when viewed in daylight so i can't really tell ! and i havent been able to get a dry day when i can have a proper look at the tracks for the heated rear screen
