Crinkling new paint
punkieys17
Repairing damage on paintwork caused by my dribbling cavity paint on the recently replaced sills. First base coat went on well. Second crinkled. Can anyone advise what I did wrong please? Spraying base coat on the rubbed down 2 pack clear coat underling base coat.
I had a similar problem on the wife's B200, had a tin of spray paint mixed up at the local paint specialist, after the first coat looked ok so more coats applied, next day the paint had a crackle finish.
I put it down to reaction to the 2 pack, laquer and base coat mixed together. Will try old fashioned solid Halfords paint next time.
Could also be the first coat had not fully cured - was it cold when you applied it or was it done in a warm garage?
This would be my guess. In my experience you have a window to get a second coat on that's quite short, so that it degasses along with the first coat. If i miss the window i leave the first coat to fully cure- like a week. With wrinkle paint you purposefully spray a heavy-ish coat then let it skin, then spray a light coat which when it starts to cure contracts and causes the wrinke effect. Ive found especially with paints like hammerite that take a long time to fully cure you have to be super careful. Either leave literally a minute or so between coats or leave it for a good week.
