I also have a few and leave them on charge for weeks at a time. Just period pally check them every few weeks - especially when you first use it to make sure that the battery is receiving the charge and it’s not overheating, etc.
A CTEK MXS 5.0 would be the obvious choice, but a CREO MXS 10 would be fine too. You simply connect the red (positive) crocodile clip to the Red (positive) charging point under the bonne, and the black (negative) crocodile clip to an Earth point nearby.
Then connect the CTEK charger to the crocodile clips and plug it in to a mains socket. Then all you need to do is select which type of battery it is - first select the car icon and then select the AGM icon - and you’re done. Let it do it’s thing.
The status lights will tell you which stage of charging (or maintenance) it’s at. Don’t be tempted to use the RECOND function with an AGM battery - the charger will allow you to select that combination but advise that it should not be used.
