CRTD2 Diesel Tuning Box
I fill the tank to full and take a note of amount in ltrs / and clocked miles. When the red bar appears on the dash I not the miles traveled and with a few calculations and the average m/p/h indicated on the computer i have a result. I have also disconnected the box and used the same formula to check the original standard results.
I can agree with the figures, as I fitted a box from TDI Tuning to my wife's Dodge Avenger, and have seen better fuel figures. But more impressive for me is the extra torque. Much better acceleration now.
Sorry to butt in when my car is not an MB, but Experience of using these boxes on the VW forums seems a bit sparse.
I have recently purchased a TDI-tuning.co.uk box for my MK7 VW Golf GTD. Stock 181BHP (184PS) and the dual channel box ramps it up to 239BHP (243PS) apparently, with mpg gains. I have been scrutinising my mpg as it is 30% off published combined figures. On paper it is 20% more efficient than my last car, a 170TDI VW Scirocco, yet cannot even match what the Scirocco was doing in the same usage. I’m getting an actual (brim method) 42.5mpg consistently (which must mean not much variance in my driving style), but indicated varies from 44 – 50mpg. The Scirocco was 50mpg indicated and 45mpg actual on short journeys and 10% more for longer journeys. I drove the Scirocco a lot harder than the GTD too. To say I feel a bit diddled by VWs claims is an understatement.
The TDI-tuning box was applied and I ran it on the middle setting for a tank, not altering my driving style. Brim results confirm 42.5mpg, although indicated mpg discrepancy increases. No actual increase in mpg at all. Top setting is savage on power and torque, but comes at some mpg cost and more frequent regens.
The only thing these boxes seem to do for mpg (in my case at least) is increase the MFD calculated mpg because the box is altering the signal that the ECU sends out to the common rail to calculate mpg. The car ends up using more fuel at any given throttle opening than it thinks it is, due to the modified signal which is invisible to the ECU and MFD, if you use less throttle (with the box) to achieve the same cruising speed etc then the car will be thinking it is using less fuel and put up higher mpg readings.
The only gains I could see really happening are those down to increased torque allowing you to be in a higher gear than you otherwise would be, so we’re talking those who cruise at a speed that would generally be in a lower gear than you are actually using, maybe in the 30-40mph range rather than full motorway/highway speeds whereby you would always be cruising in top gear. Would that really add up to 10% for most drivers? Unless the box manages to provide a better injection cycle/spray pattern etc than standard (which it doesn’t claim to), I can’t see the car getting appreciably more efficient at burning fuel.
Are all these gains people are seeing down to actual (brim method) or indicated MFD figures?
I would say, based on my own experiences that torque and output are well up – buy the unit for that rather than false high MFD indicated mpg gains.
Conclusion
Well, its been over a year with this unit fitted and the indications are that I have an all round improvement on torque with less turbo lag and with the added increase of 4 MPG on a middle setting. I have tried the top setting with a noticeable increase in power but loss of MPG. In conclusion this unit will pay for itself in a couple of years and give you a little more power for those days when you think you need it. :bannana:
I had one of this fitted to my E90 BMW and all it did was put the car into limp mode plus loads of error codes, so I sent it back for refund , IMHO add on tuning boxes are a massive placebo and I would not go near one again :(
