reflexboy
I'm sure this has been asked many times before but I'm reading conflicting things.
I want to Recond and charge the battery in my W212 using my CTEK 5.0. CTEK says I don't need to disconnect it from the car and to connect it directly to the battery terminals. MB's owners manual says to "Only charge the battery using the jump-start connection point." Which is correct?
Also, in Recond mode, the CTEK apparent kicks out 15.8V but the MB owners manual states: "Only use battery chargers with a maximum charging voltage of 14.8 V."........Which one is right? I'd prefer just to leave the battery in situ but do not want to damage any sensitive electronic stuff.
I'm then also reading stuff relating to where to hook the charger up to with regard to the battery control module (BCM)
These CTEKs are meant to be fit and forget??
Any experience or pointers greatly appreciated.
