Cutting wooden trim
proser
Stafford
W210 E320Cdi Estate
Has anybody cut holes for extra switches in the wooden centre trim panel.
Want to fit the heated seat switches, but I'm not paying MB about £300 to replace the centre dash panel with the holes already there.
Could you not find a seconhand one with the holes already in it? Have you looked on ebay.de?
Ive cut them for extra switches . Cover the area of the switch with masking tape and mark out the shape of the switch with a pen . Use a hole saw to start the cutting . The insert a coping saw into the hole made by the hole saw , and roughly cut out the switch shape . Then finish off to the marks with a fine file ,and only file down wards so as not to chip the laqure .
Its slow progress but it can be done .
I have been looking, but the combo needed is like rocking horse doodahs :crazy:
It will need to be bur walnut with comand, std heating controls, rear wash/wipe, heated window, hazard, c/l , anti theft and then the heated seat switches.
A tip for cutting out, is to first mark the hole to be cut out with a stanley knife with a new blade in it. This will stop the wood from tearing.
on my car the wood is only a veneer which is stuck to alloy.
that Stanley knife idea would probably cut through the veener and mark the shape on the alloy underneath.
I have done it numerous times using a Dremel with a side cutting drill bit to cut a hole slightly smaller than required , then one of the rotary polishing stones to finish off to the exact dimensions required .
Dremel as mentioned above, just be careful which speed you use so it doesnt heat up too much
