SEM
- Apr 19, 2004
- Location
- Tamworth, Staffs
- 2007 C220 CDi SPORT & E350 Coupe Sport
Does anyone use one of these... I bought the Halfords
http://www.halfords.com/opd_product_details.asp?id=16654&type=0&cat=113
Power unit basically to keep son happy, playing his playstation in the back of the car. This plugs into the lighter socket in front of the arm console
Now my problem... on a test run, his playstation keeps turning its self off. The AC unit should bleep if there is a problem with power surges etc. The light stays on the AC unit and has to be switched on/off. When the car is stationary, it works fine... when I throttle it a bit the I get the problem
There is an earth ground wing nut on the back... and it says in the leaflet that the car should be earthed... which I presume...is.
Don’t know if I should try a surge protection plug on the playstation, just incase its a little sensitive
Also just wondering if the AC unit is powerfull enough its only 120W
Ta SEM
Edit Note
The official PS2 slimline power unit is not available yet and a i cant use the original PS2 converter.
Ta SEM
Edit Note
