joeysnowey
- Apr 6, 2012
- E320 CDI (Retired) - Now driving R Class 2009 Sport
Hi all, I am at the end of my tether with my R320. I love it, it's beautiful and I have enjoyed it since buying it around 6 months ago, except for one fault I just can't seem to get diagnosed.
The fault is very intermittent, just happens occasionally. What happens is the car will stutter under acceleration. It's usually minor, just a few seconds where the throttle doesn't work and then the acceleration kicks in and you are going strong again. But it's disconcerting and worrying, and obviously I am not sure what the problem is so I assume I could break down any time.
I have had it looked at by a Merc indie and he changed fuel filter, glow plugs (they reported one faulty), and nothing has cured the problem. Last resort is fuel pump, but it's pricey and I just can't afford to buy one of those if it won't definitely sort the problem. When the car does the bunny hopping it flashes a warning triangle and writes a fault into memory. When having it read the fault reads as "low fuel pressure". therefore I am advised it's probably the fuel pump but no way to know without changing it, and I have a funny feeling it may not be this, and certainly can't afford to fit a new pump just to suck it and see!
Has anyone ever heard of this problem before? Its much like in the old days when a car was missing on 1 or 2 cylinders, you stick your boot down and nothing happens, then you feel a bit of a kick and stutter a few times, almost like there is an intermittent fuel blockage, but garage says the fuel lines look fine.
Any ideas very much appreciated.
