Hi guys, I've had a few issues with the car and thanks to everyones help its sorted so far.
I BELIEVE I have a rear SAM failure but will put the signs and symptoms below if anyone can help.
Firstly , It was raining loads, the car started (slowly) but had a light sensor fault. The next morning it wouldn't start. I removed the SAM and it was wet because water had leaked from the boot.
Opened the boot after some difficulty ( the manual lock was seized and because I removed the SAM I couldn't get back in.) after reconnecting it the following systems work:
Central locking works properly.
I can hear the cd changer spinning up.
Im getting a SRS fault occasionally.
The car doesn't turn over. I can hear a clicking from the engine when I turn the key but it wont start.
At rest the speedo is fully lit. At one click it dims and some of the lights flicker. and when I try and start it makes the clicking noise and it goes black / dark..
The battery voltage is 10v when disconnected but when I connect it to the car at rest its 8v.
Was thinking of getting a new rear SAM but merc say they will only provide the newest version so it will have to be recoded with STAR.
Any mobile mechanics that can help in East London / Ilford area!!!??!
