diesel fuel leak
silverarrow
injector leaking ?? common problem how much for new one is a recon possible and who to use ?? replaced the copper washers and i am thinking leak from o ring on fuel return pipe new pipe and t connectors on order but need help with injectors
car w202 2.2 cdi 122 bhp :mad: :mad: :mad:
up date injectors recon exchange for £100 each and new copper washers feels like a new car no turbo lag.
i was correct with o ring mbz have changes them to rubber that can with stand diesel fuel
leak made a mess of the sound insulstion not replacing in case leaks again leak only tiny but over time a lot of fuel .
would advise all to check o rings and fuel return pipes
Keep an eye out on Ebay. I saw some NEW injectors recently for £35 for two.
