differential oil change
japimport
The Emerald Isle
mercedes c200 sport,mercedes c200 elegance.
hi ther i have a c200 sport year 95 im going to change the diff oil whats the right oil to get for my car thanks for your help
EP80/90, it takes 1.1 litres. Go for synth if you can get it.
As above.
You'll need a big allen key 'hex' driver to undo the filling and drain plugs (14 or 17mm IIRC). Remember to undo the filling plug first in case it's stuck/siezed.
You don't want to drain the diff to find out that you can't refill it ;)
Will
Does this procedure apply to all models? I want to change replace the diff oil on my S320 W220, looks like a nice easy saturday afternoon job!
As above.
Will
Good advice! did mine a while ago stuck in full syn 75/90 iirc.
Lynall
