E240estate
- Aug 19, 2014
- 2003 S211 E240 Estate; 2003 W638 Vito
Got 2 old Mercs, a CLK320 and a s211 E320 so it's worth me investing in a specialist diag setup.
I already have an obd2 scanner and WIS/EPC set up but obviously that doesn't let me do a lot with the car itself.
I'd like to get something that I can use to disable the sbc pump on the 211 so I can at least work on my own brakes. And access other modules such as transmission to help with fluid change etc and generally diagnose any faults which crop up.
Can spend a hundred or three on a setup but not a grand. Please help, its a bit of a minefield and info is light on specifics, am I looking at an xentry pass thru set up? What hardware is required? I read a lot about a C4. I don't think the icarsoft mb2 is going to be enough but could be wrong.
Need a bit of guidance ideally. Tia.
