GrahamC230K
- Jul 14, 2002
- Audi A3 & S4 quattro
As I have made a habit of the last few years, I am moving AGAIN!
The house I am oving out of is very new and so all the walls are plasterboard. That being so, anything with any sort of weight to it has been mounted using plasterboard fixings.
The problem is now, I must comply with the clause in the contracts along the lings of "walls must be made good after removal of fixtures and fittings".
When fitting things to my walls of any weight, I found the fixings shown below to be the best:
How it works:
You drill the plasterboard and insert the "anchor" so it's teeth grip the front of the plasterboard. Without your fixing, you screw the screw into the anchor. It spreads it's metal anchors behind the cavity. You then unscrew, and screw back in with whatever you are mounting in between.
GREAT fixings.
But how do I get these pesky things out to fill the holes now I don't want them?? The screw comes out, but of course the anchor is mounted firm.
I can fill a small hole, but have visions of having to hire a handyman to cut these blighters out, with a hole large enough to remove the exanded anchor. Someone tell me there is an easier way.
TIA
Graham
How it works:
GREAT fixings.
TIA
Graham
