Dome light W203
Longneck
2005 C180 Elegance
Hi all
Got a prob with me Dome Lights, will not come on at all. Checked fuses ok. Any ideas
Longneck
Obviously don't know how familiar you are with these cars, or how long you've owned it, and not sure what you mean by dome lights. If you're referring to the interior lights, wait until darkness and try them again. They don't illuminate in daylight when set to auto. They have a daylight sensor in the circuit.
I tried it at night but still nothing, the three way switch in overhead unit should be : on/off/auto.
Tried all positions but no joy.
Longneck
According to the fuse chart, there are two fuses for the dome lights. Numbers 3 & 9 which are both located in the boot fusebox.
Do the reading lights not work either or is it just the main light?
The lights that are not working are as follows:
Courtersy lights (front & rear)
Map lights
Mirror vanity lights
Puddle lights at bottom of doors
Checked all bulbs & fuses, all OK. Is they a relay that may control them
Don't think there is a relay. Quite possible it's a fault with the rear CANBUS, but get it checked by an auto electrician, before replacing it.
Don't know if these diagrams will help you, but hope they will. (Taken from a well known workshop manual for the W203).
Click on the images to view them on Photobucket and use the magnifying glass icon to enlarge them.
