Hi all. I have a 2014 E-Class 250 Saloon, bought from new in Sep 14. I have had to ask the dealer on 2/3 occasions now to look at the gear shifting logic in 'Econ' mode. The car stops shifting at its normal range and allows the RPM to increase to approx 2800-3000 RPM before changing gear. During this situation I can also no longer select 'Manual' mode either by 'paddling' the shift or by selecting the manual mode through the pedestal mode selector, but I can shift up using the paddles once the RPM reaches approx 2300-2600 RPM; I can't shift down using this method! This results in a high RPM and uncomfortable acceleration! It was checked and corrected 6 months ago, but I still noticed occasions where it appeared to shift gears at higher than normal RPMs. This week it stopped working normally and is now shifting gears at just under 3000 RPM all the time; I now also have the engine diagnostic light lit on the dash. Very occasionally, I can stop the car restart it and the gears operate normally for approximately 1 min and then it reverts to this non-normal mode. The earliest I can get the car seen is on the 22 Dec. Has anybody seen this before? Thanks.
