Hi Guys
Excellent forum hope you guys can help me!
I have a W211 E270 CDI 2002, I unfortunatly bought a pup that had alot of problems. The car had water in the ECU & SAM unit and everything got pretty fried. I had the car taken to MB but they quoted me 4500 pounds to get it fixed.
With no knoledge of cars I decided to fix the problem my self or at least give it a go
I took my ECU to a boosh dealer who transfered all the data to a new ECU, i then also purchased a SAM unit from ebay for 70 pounds.
I have fitted both of these and to my utter amazment the car started first time.
However I have the following problems and warning lights?
A red battery symbol - take to workshop
Lost Power steering
Electric consumer turned off (warning light)
Braking is harder than normal
SRS (warning light)
EPS (warning light)
The interior lights no longer work
The radio & satnav unit will not work
The car however actually drives fine.
I have read a few forums and am not sure if the above problems are all connected. I have read that if there is a battery problem then things like heated seats ect will not work to preserve power. Do I need to get the cars electrics reset or maybe I still have another problem with the main battery control unit or the aux battery, this is all stuff I have read, I no very little about cars.
Also, does anybody know what the part number is for the cover, that covers the SAM unit & ecu on the left hand side of the engine bay, I cant seem to get one anywhere, what is the correct name for this cover?
Does anybody know what port 10 & 12 are used for on the SAM (front)unit as I had great difficulty getting this connector back in......2 pin plug green and brown wire.
Any help or ideas would be helpfull.
Regards
Lost Power steering
SRS (warning light)
EPS (warning light)
Regards
