E300td ... Front Fog Lamp Bulb
johnsco
Leeds, West Yorkshire
E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
Hi fellahs.
I'm sure that this has been asked before, but I'm pretty new to this forum.
One of my front log lamp bulbs has failed on my 1999 E300TD **********.
How do you get at it ... From the front or from the rear ?
It's all too low down for an old man like me.
But - I'm rarely-beaten.
Help please.
Johnsco
Just done mine 1/2 hour ago what a tosser:mad: little drop down panel on undertray twist screws pull panel down and then fidget around blindly until bilb comes out:D
Seriously once panel down, plastic cover on the back of the lamp is held on by a clip on the bottom prise this down then remove the cover, bulb is held in by bent wire clip as usual but my bulb was seized into bulb holder.
This is a facelft 2001 model not sure what year yours is.
Getting the plastic cover back on was a pain.
If you could get it nosed over a kerb to see what you are doing it would then be an easy job, but i was to lazy to move the car, and as its Avantgarde it pretty low as std.
Lynall
