scoobysook
hey guys, am having a few probs with the old girl unfortunately.
A week ago the car on starting from cold did not change gear and was stuck in second gear. from reading threads here, i deduced it going into limp mode. However if the car was allowed to warm up abit and the key turn off then on again, the car would change as normal.
was going to get it checked this week when today it went into permanent limp mode: 2nd gear all the way, 40mph max!
The car had a gearbox oil and filter change 6 months ago and did not have any immediate problems afterwards. I did notice a squeal from the engine like a slipping fan belt begin about the time of the problem appearing, but only when hot (coincidence?). The car has done over 150K.
I have searched the threads here and have found some info to work with. Could it be a sensor/switch on the gearbox? How could you tell if its oil creeping into the loom? could it be the metallic plate in the gearbox? Would the fault show up on star diagnosis?
Have have an intercooler prob before whiched took ages and lots a money to diagnose, and hope it wont be the same with this
Any help you can provide will be much appreciated!
