yes it can, not too bad. all this from memory......
you need to remove the pipe below (from intercooler) completely, undo the 3x torx headed screws and disconnect the vacum pipe and pressure sensor wire. then the valve can be slid off the exhaust gas feed pipe and manouvered out from below, it is a fiddly job though but can be done.
