Hi everyone
Recently got 2009 E350 CDI coupe and I am struggling to find out why engine is idling rough when cold. Maybe someone here can give any advice..
The garage initially was saying bad EGR valve.. values going over 100%. Replaced EGR.. values within tolerance but still running rough when cold. After driving 50 or so miles after flooring got check engine light, P0404 range/performance problem of egr.
Was thinking the replacement part was faulty (ebay one). Decided to unplug the egr one night and car was idling perfectly fine apart from obvious two error codes because of unplugging...
Maybe coincidence or not.. since driving with unplugged egr in limp mode idle was perfect all the time. So decided to delete egr.. and problem came back after deletion.. runs lumpy and rough when cold. Around 60-70c gets a lot better and completely smooth at around 80.
I have also replaced air filter, fuel filter and did put in diesel cleaner. No other errors coming up.
Also I havent put blanking plate on, maybe the valve is stuck open since reflashing ecu? To my logic it should stay closed.
