Hi Guys,
Firstly no EML light is or has shown with these troubles, so I am a bit in the dark here. Basically my car wont regen DPF in over 7000 miles and iCarsoft is showing the soot content at 29gram! I feel it has lost some acceleration so trying to find cause.
What I did notice, and not sure if it is just iCarsoft being typically false with readings, is that the "On/Off ratio of exhaust gas recirculation" is always showing as 20% and never changes. I could not find any other live data related to the EGR and so not sure if this should change depending on how much the valve is open or closed?
I did remove the EGR to check it isn't caked in carbon and it looked fine and replaced with a quick clean.
Can anyone advise on how I could check my EGR is working correctly?
