I have some slight misting since I refitted my turbo charge pipe.
I was careful when refitting with the green O-Ring and had it on the turbo first, gently pushing the pipe on so to not nip the seal, although on first fit I may have pushed the pipe all the way onto the turbo so not sure if this is most likely damaged the green o-ring?
What is strange is that the pipe doesn't fit fully home onto the turbo, and there is no movement as the support bolt on the intake wont allow it. Is this the correct fitment?
