htavs
Hi, I need some help on an issue on my car, the car will start up and drive what appears to be fine except its in limp mode so it will drive but I have no kick down and its slugish this all happens with no engine management light on.
So I get my engine management/reset tool plug it in and it brings up the p1402 code but not as a stored code but a pending code. If I erase the pending code p1402 I have full drive back ie its no longer in limp mode it drives perfect. I can drive it all day and it wont bring up any pending codes or stored codes. However if I turn the engine off and restart the engine then its back in limp mode untill I reset it, then its fine till I start it again.
Ive changed the EGR valve Ive cleaned out the throttle body which some call the EGR, its linked to inlet and the EGR intercooler. (Next job will be to clean out the EGR Intercooler)
Still the issue is there.
Any help would be apreciated.
Mike
Mike
