ChrisEdu
- Sep 5, 2005
- Location
- By the southern sea
- E320CDi Estate - gone E320CDi Saloon - written off CLS 350CDi Coupé
So, yet again, my incredibily reliable (NOT!!!
) E320CDi has gone wrong. This time a fault message has been displayed showing EL POWER CONTROL - VISIT WORKSHOP.
This first happened as the car kicked-down to join a dual carriage way. The car went to limp mode and I pulled over the the roadside. After switching off, and then restarting, the fault seemed to have cleared and the car continued to run fine until about 12 miles later when, again as it kicked-down, the same message came up and I lost power. I got a mechanic out, but he didn't have a diagnostic test, and when the car was started up again the message had gone, so he didn't know what to suggest. I decided to leave it to see if it would happen again.
All was fine for several hundred miles, until I had to refill. Shortly after refilling, I pulled out quickly (kick-down again) at a roundabout and the message came back, although the power level seemed to remain fine. Since then, I've done another hundred or so miles without and trouble.
So, any ideas what might be going on? Does this sound like an urgent problem? Is it just coincidence that it has happened twice after refilling? Any ideas folks?
Thanks for any help / ideas.
