electronic circuit cleaner spray
deian
Liverpool
'01 W203 C200K Auto Estate
To those who follow the oil, what spray do you use to clean the ecu circuitry? (apparently there is one that takes hours to dry).
I'm thinking BlackC55 would know?
Also would it be a good or bad idea to coat the circuitry in a protective film/wax of some kind? (i'm sure there is something about, but i'm thinking heat distribution may be an issue?)
Buy Precision Cleaners & Degreasers ITW Chemtronics 400mL Aerosol Precision Cleaner & Degreaser For Various Applications ITW Chemtronics ES1010EBGS online from RS for next day delivery.
contains mainly hexane and isopropanol which are fairly innocuous solvents see http://docs-europe.electrocomponents.com/webdocs/0176/0900766b80176bb5.pdf
and
http://docs-europe.electrocomponents.com/webdocs/001f/0900766b8001f15d.pdf
however be wary of a similar product in a smaller can
Buy Precision Cleaners & Degreasers Chemtronics 250mL Aerosol Precision Cleaner & Degreaser For Various Applications Chemtronics ES1607E online from RS for next day delivery.
as it contains dichloroethyene which is a very effective degreaser - BUT and can have a bad effect on any elastomer [ rubber] type compounds viton etc and some plastics.
Check the ingedients of whatever you buy!
