Niks
- Mar 8, 2008
Can a E280/E320 ECU be flashed to copy the ECU data from a 1995 C36 using HFM? If so, this should be plug & play and still retain my original engine loom?
If I use the 280 ECU on the 36 engine, will this limit the 36's engine power to 197bhp as per the 2.8 M104? Or limit it to 220bhp as the 280/320 use the same ECU? Or is there a difference between the 280 and 320 ECU which doesn't make them the same?
Just need this bit cleared up.
