the only pipe I changed was the smallest one out of the two that come from the fuel filter. Where is this high pressure pump locateddazzaf1 said:I have same car as you , just replaced the high pressure pump and plastic pipes , took a while to get all the air out, should be self priming. Have you disturbed them at all ?.they are very brittle. Just a thought. Hope youget it sorted soon.
People are throwing part names at you randomly and you are none the wiser. May as well tell you that it's the flux capacitor on the warp core unaligned with the dilithium matrix.
I would start by replacing all of the plastic pipes....
