EPC question
Charles Morgan
Mercedes 250CE W114, Alfa Romeo GT Coupe 3.2 V6
I've been going through the box of parts received from Rivervale and noticed that only one of the two lengths of head bolts have been supplied. As other parts are difficult to place (or just wrong) I thought I'd get on the EPC (which I've managed to get back into).
Entering my chassis number gets me nothing on engine parts, is there a different way of interrogating the EPC for engine bits? Or if not, I have head bolts A6159900312 and want to find the number of the other bolts and washers for both (the replacement bolts are slightly longer so I assume they need thicker washers?).
IN EPC YOU NEED TO SELECT Maj Assy -M at the top of the group listing then engine housing -subgroup engine housing- parts 1/2 select 2 to see the cylinder head rather than the crankcase drawing.
there will be 14 10mm allen head machine screws for the CHG and 4 6mm allen head machine screws for the timing chain housing [ the smaller machine screws have no effect on the CHG ]
the smaller 6mm screws are listed as
217 combination bolt N914020 008007
218 washer N000433008406
The washers for the 10mm machine screws A6159900312 are listed as A1100160476 but check against your engine number
F11 allows you to look up by part #.
