Tried so many things, checked every fuse, cleaned checked wiring / ECU/ESP connectors. Swapped out another ESP ECU, still the same.
Friend scanned the car with decent Snap on Scanner and he says is getting no comms with the ABS or ESP.
From reading threads I am understanding the car will 'lock out' if the ABS is faulty and the ESP / EGS will also not register on the system or will show faults.
Car unmovable, will not start but only way to make it start is if you unplug the ESP ECU, then it will start but it will not go into drive or any other gear as is stuck in park.
Could it be ABS that is causing all of this, any ideas?
Also would STAR show what is going on? If so though would need to trailer it to garage to get it on STAR and you cannot move the thing as its stuck in Park!
