Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
Last time I went under the car I noticed there was a small hole in the exhaust caused by the welding for the hanger burning through the alumised coating. I filled this with exhaust paste for the MOT but intended to deal with it as and when.
Tonight was the time.
Removing the exhaust is straightforward on an E300TD apart from the front connection near the turbo. Due to the steering gear being in the way the exhaust has to be split at the front pipe and worked round the steering.
Unless you have a workshop ramp available you need to split the pipe halfway down the car as well to get enough room to lower the pipe sufficiently to allow the convoluted pipe to pass round the steering.
The front pipe is held with a clip ring which looks awkward to deal with but it can be undone using either large water pump pliers or a G cramp.
All in I'm pretty happy as I can now tell the car is a bit quieter and at no cost.
The pics show the hole as visible, removing the clamp, the actual hole and the finished job after welding a stainless plate on and reattaching the hanger.
The point of this post is to show how to undo the retaining spring clip and maneuver the exhaust round the steering gear.
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
