I have 1993 MB 190E 2.0 litre engine. The previous owner took in for MOT and it failed the "closed loop cat test".
The problems where specifically the "fast idle" CO and HC tests where it scored 6.3% (max was 0.3%) and 206ppm (max was 200ppm).
It also failed the second fast idle test with similar results. However, the car appears to have been retested and passed - quite what the previous owner did to make it pass I don't know.
I'm just trying to narrow down what the problem could be.
The car has a slight rough idle (but the RPM needle doesn't move). It will surge and then relax for 1 sec intervals in a cycle and seems to improve as the car will warm up. Could this cause it to fail this part of the emissions test?
Also the car has a very tiny oil leak, but it doesn't burn any oil, has no white gunk in the coolant, there is no blue/white smoke on cold start and it doesn't smell of burning oil. Its suspected to be a head gasket but the problem has existed for 3 years and hasn't worsened. Could this cause a failure of emissions?
Or is it the dreaded CAT that is on its way out, though I'm not hearing any CAT rattle.
