Fault Code Reader
imadoofus
This and that.
So if I decided to build myself a Fault Code Reader from my W124, how would I use it?
Where's the diagnostic port, and where can I find a list of fault codes?
TIA
PJ
PS: I am assuming a 12v LED, a momentary push switch and a couple of connectors is all I'd need...
I could have sworn I'd seen something, but when I did a search here, it didn't come up :confused:
Richard, where are those part #'s from?
Those are radio shack (remember Tandy) part numbers from the states.
This is what I ordered from Maplin..... You wont need quite so many LED's or LED holders, I ordered 2 as I wanted one for another project.
Part Description Qty. LineNett LineVAT LineTotal
GJ88V 20mm QB 630ma 10 PK 1 1.270 0.222 1.49
N75BQ ABS Box 120x65x36 1 2.630 0.460 3.09
FH59P Red Push to Make Sw 1 1.100 0.192 1.29
L86AZ Banana Plug Gold Red 2 2.880 0.504 3.38
L87AZ Banana Plug Gold Blk 1 1.440 0.252 1.69
CJ66W 3mm 12V HE Red LED 2 0.660 0.116 0.78
DA59P 20mm P/Mount F/Hold 1 1.270 0.222 1.49
YY39N LED Clip 3mm 2 0.260 0.046 0.31
hard core moakesr!!
We have a launch kit and that is supposedly able to read codes on my W126 but never managed to make it work... i think my port on the car is short of connections for some reason..
hard core moakesr!!
Which system did you want to read codes from?
W126 connector is as follows
can you use this in conjunction with the cs1000 data sheet you put on for Olly for the diagnostics.
Most definitely, I know it works perfectly on my 1991 R129, and allowed me to diagnose my ADS system problems.
This is what a forum is all about.
Hats off to ya.
Imadoofus
Your's is no good as you need 3 different colour bananas, otherwise you will not know which one to connect to appropriate socket connection.
I chose yellow to plug into the appropriate socket of the system being tested ie HFM-SFI engine management codes is number 8 socket.
SRS codes is a different number socket etc etc
He's done a black lead, red bannana for signal..
