Fault Codes Found W211
GeoffWestWales
West Wales
Mercedes E Class
Took delivery of my iCarsoft MB V 2.0 Scanner Yesterday, just scanned it as the ABS light is on, I got the following codes/messages:
056 S9/1 (Brake Light Switch), normally open contact and in a box next to this message it says AUS
P2402 State: Historic
The left rear wheel rpm signal sent from the traction system via the CAN bus is unreasonable
P1861 State Historic
Could this be the abs sensor on that wheel?
6210
State Historic
ABS anto - lock braking system control
C225C
State Historic
Event: ABS control
Anddoing a live data from the SBC pump, I got the following:
A7/3b1(Front Axle pre pressure sensor) 5.12 bar
A7/3b2 Reservoir pressure sensor 149.41 bar
A7/3b3 (Left front pressure sensor) 4.39 bar
A7/3b4 (Right front pressusre sensor) 5.31 bar
B37/1 (SBC pedal value sensor) 14.66mm
Does the above sound like a healthy pump?, any pointers would be greatly received.
6210
State Historic
C225C
State Historic
Event: ABS control
Delete them all after making a note and see if they come back
Did that yesterday and they all came back, sounds like a wheel sensor on the rear wheel is one, not sure the brake light warning means its good or bad as brake lights are working but as its a cheap fix ordered a switch will whip off the rear wheel and have a good look at the sensor and ring on the drive shaft and see what I find
Forgot to say doing a live abs test it was reading roughly the same on all wheels so is the sensor for the abs is the only sensor on the wheel or maybe there are 2 sensors?
One of the sensors might be failing intermittently.
Looking at the faults,do the SBC Reservoir have that sort of pressure,the sensor is saying you have 2000 ilbs per square inch in that tank,seems alot to me.
I think they do run high pressure but not sure how much is to much, but I don't get an actual fault code when scanning the sbc pump, as I had the brake switch warning will swap that even though it seems to be working but thinking it must be the reluctor ring on the rear near side wheel, will have a look later as need to check on how worn the brake pads are so will have a good poke around, but it makes the most sense as getting readings from all four abs sensors when doing a live scan, may be intermittant at high speed so seen as the reluctor ring is the cheapest may as well start there and see how I progress, wish me luck :D
