Fault light beam
aktey42
Turkey
Mercedes Vito W639 111 CDI
Hello, I have a question.
i open short-lights and console fault light lamp is on. It's okay for short-lights did not open. I check all headlights are working normally.I wonder what can I do?
Check all the lights including the numberplate ones.
Turn the switch on to sidelights only to see if that brings on the warning.
just wait until that bulb which causing the problem will burn out, it can cause the higher current when is nearly dead :)
...or change all bulbs if you have spare ones, one after another with checking is still error there
Thank you for replys...
When I went to a Mercedes authorized serviceman and brain (SAM) have to change the headlights if any distress they said. As I said, when I just dipped beam is on. Normally, parking lights or does not light. it's normally.
But SAM is very expensive and i don't want change.
"Sorry my english bad"
my car this way, 10 days ago were xenon lamp. I changed the original and H7 lamps. But the problem is not resolved.
