- Jan 21, 2005
- Location
- Mittel England
- Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
I assumed there must be concealed tail lamps somewhere or other, but couldn't see them.
I believe if the lights are removed the car may still be driven in daylight and indeed will pass the MOT.
BUT
Should the conditions require lights you are stuffed!!
No, the car must have a working rear fog light (drivers side), brake lights and reverse light to pass an MOT.
talbir
talbir
I think you may get conflicting information depending on who you ask and even which MoT station you go to.
I always thought that if any lights were fitted they have to work and you then have to have all of them, but if none are fitted and the vehicle is for use only in daylight then you don't have to have any fitted
Quote from the MoT testers manual which of course may be out of date
"This inspection applies to: all vehicles except those used only during the hours of daylight, and which are not fitted with any front or rear position lamps or have such lamps permanently disconnected, painted over or masked If no front or rear position lamps are fitted to a vehicle, there is no legal requirement to fit any other lamp."
Wow, that's unreal...even F1 cars have a flash light on the rear![]()
Get away with murder with that manual !![]()
cheers
talbir
cheers
talbir
good work, but how can this car now be driven ?
I mean, he's blended in and sprayed over the rear lights !
but AFAIK that light on F1 cars isn't a brake light - it's only for use in adverse conditions - you wouldn't be able to drive a "daytime MoT" vehicle if it was raining as the law says you have to use dipped headlights.
I agree though, it would be a nightmare to follow in traffic
