Fuel Leak - part number/name needed please!!!
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
Hi
1994 W124 300 Diesel:
i have a fuel leak from the push fit black plastic plug thing that is circled in the attached 2 pictures.
there are 3 of these next to each other going into/out of the fuel filter housing.
the other 2 seem fine, but the one that leaks seems to wobble a bit as if a seal or o-ring has perished.
does anyone have the part number for the particular O ring that sits on the push fit plug, or maybe just the part number for the whole thing (black plastic thing just incase). i am assuming this part will be pretty cheap from a dealers....
any advice/help would be appreciated.
currently, the fuel is spitting out of this when the engine is running. not much but its making a mess of the engine bay and is wasting precious fuel!!
thanks - pics below:
derek
Didnt you get that car with any warranty?
ahh, almost forgot you invalidated that by filling up with veg oil. :D So you found the % limit then for this cold weather?
thanks - off to the dealer today. Hopefully an easy/cheap fix. :)
derek
