Hi guys
Newbie here, please please can someone help me, I've got a 2007 clk 220cdi, I've had this problem where the ecu light comes on my dash and the car goes into limp mode, I've read the codes and it comes back with p0088 which is meant to be high fuel rail pressure, So I took the car to have an inspection done and a full diagnostics they came back with fuel monitoring issue and was advised that it was either the fuel pressure regulator on the high pressure fuel pump or the fuel pressure regulator on the fuel rail, in which I changed both and the fuel rail sensor while I was at it, still no change any ideas??? Any help would be great thanks
