Fuse rating?
Uncle Fester
kent
C220 CDi (S203) auto 175k
Hi, probably a stupid question, but the manual doesn't cover it.
Rear wiper motor seems to be on fuse 14 in the rear fuse box (C220 diesel estate) but 14 is listed as a spare with no rating in the Haynes manual, can anyone shed some light as to the rating of this fuse??
The switch illuminates when I press it, but the wiper doesn't move.
The washer works fine.
Could the motor be jammed?
update:
Just been out to look, and the fuse in teminal 14 is a 15amp fuse, and appears to be intact.
Check for voltage at the motor connector while the button is pressed if the fuse is ok.
OK, thanks, and I guess if no voltage, then check/replace relay,and if voltage present then motor is dead?
Another little update:
This morning I switched on the heated rear window, and heard the relay click, but nothing more happend, so is it a problem affecting the whole tailgate?
I haven't checked to see if the third brake light is working, but will check that later today .
High level brake light works, so there it's not a tailgate issue....
Is it worth checking/changing the relay to the motor (relay 6 I believe) ?
Any ideas?
Have a bump again from me would be interested to know the solution as my rear wiper is inop too, switch lights up , rear washer works but the wiper wont !
JUST SEEN THE DATE : HOLY THREAD RESURRECTION BATMAN !
what was the solution in the end?
