Mcnasty
Folks,
I have a double garage which I now use to house my w211, I also have a fair bit of stuff in the garage so the Merc is parked in the middle.
The problem I have is with water from the vehicle dropping onto the concrete floor, and running under the work bench and various other housings I have in the garage. This is due to the concrete being uneven in places where there are small channels which the water runs along. I have considered skimming over the channels, but when the water is excessive due to the current snow/water, the water would still run.
My initial thoughts are;
1. Get some sort of matting that sits under the vehicle and has a lip at the edge which ensures the water doesn't run.
2. Build a small ridge with (concrete or other material) around the area where the car sits so water wouldn't travel. Then water proof the concrete followed by coating with garage floor paint.
3. Buy some sort of tiling system but not sure this would stop the water running.
It will be interesting to see what other options/recommendations that can be considered.
Cheers
Martin
Cheers
Martin
