KramEkard
Car 2010 Mercedes eclass . Had a Nightmare with injectors and seals .
Leak off pipe snapped When pulling if off injectors.
2 fuel injectors had to be replaced
2 snapped injector bolts when tightening down the bolts due to neighbour setting torque wrench to high
Failed job by my friend to drill them out
Car would turn over but not start , assumed airlock
Tried to recode the 2 replacement injectors but seems it erased all 6 of the codes and couldn't seem to get them back , ( maybe with weak battery making it look as though the codes were erased )
The numbers are not visible on 3 of the injectors .
Had car recovered to engine repair garage (£100)
Garage called today told me 2 injectors are now in it's £420 for the snapped bolts being sorted
Also told me the car won't start which I assume is airlock but they said they'd tried awhile and still can't get it to start and I told them to carry on with it ( don't know how expensive going to get )
Does anyone have any ideas to why this might be happening ? Car was running before taking injectors out .
Thank you
Thank you
