Hi folks.
I’m seeking a little guidance from the experts here, about a problem with my car’s glow plug system.
The car is an S320CDi 2009 build.
A few months ago the glow plug warning light remained illuminated and I traced the problem to an inoperative glow plug. Plug replaced, the light went out as it is supposed to after warming on start-up.
Now, the problem is back with a twist. The glow plug light comes on at cold start-up briefly goes off then comes on again. It also occasionally comes on in the middle of longer journeys.
Resistance across each glow plug is about 0.5 Ohms, and each one is seeing 5.5v from the relay control unit at cold start-up.
Am I correct in thinking that the glow plug control unit is causing the problem or should I look elsewhere? The control unit is part number A642 153 20 79 and made by Beru with their code 0 522 140 202.
Thanks for reading.
Thistle
Thanks for reading.
Thistle
