Thats pretty good. I had a fault on three outputs from my relay. I cut off the seal from the relay and inside there were four copper strips. Each feeding a plug. The strip was cut down the middle , one side thicker than the other like a fusible link. The return side had burnt away on three of them. When the relay sees no return through this link it doesn't bother switching out power. I soldered in small pieces of wire and it works fine again. I have no idea why they burnt out but i assume it was due to faulty plugs or something. I only have the car a little while so i don't know what happened before. Anyway good link Bye
