Glow plugs
amolak
B200Turbo & V350
How long should glow plugs last in terms of miles?
How many does a V220 have?
thanks
Amolak
Thanks, that's funny MB said that I had 5 Glow plugs.
Amolak
Some of the 220CDi's were 5 cylinder werent they?
Basically you usually have one glow plug per cylinder, similar to a petrol car having one spark plug per cylinder (unless it's a twin spark). Their useful life very much depends on the way the vehicle is used, lots of short, start-stop journeys will shorten their life.
Consensus of informed opinion on C class is circa 70-90K for "average" usage.
However, it is very much dependant on number of starts as against mileage.
Splitpin
Is it true that the plugs can seize, and thus require a head removal?
If so after what time frame would this occur, 2yrs etc...
tx
Amolak
plugs had up grade check part number with mbz been told best to change at 3 yrs reduce the chance of head removal
That'd be a hell of a labour bill, 2Yrs at £100 per hour. :) :)
Actually it's probably not far off that due to having to remove the engine to get the head off. :confused:
concordepilot19 said:
250 and 270 have 5 cylinders, not sure if these are fitted to V class though.
It's a 220 so deffo a 4 banger.
