dogan124
- Jan 24, 2005
- Location
- Turkey-Ankara
- 1991 w124 300td (estate) & 1988 Golf II TD
If the glow plug light behaves un-normal then one or more of the glow plugs are dead. This is something I have learned by experience and advice.
Last week I had the plugs checked out (hard start) and found one dead, the glow plug light was just as normal though.
Then is it wright to say "an unusual behaivor of light indicate a failing plug but not a must for it"?
By the way the failing plug came out to be 11 V where as the service says it should have been 11.5 V. What should be the correct grade (w124 300d 1991)? What could it cause if not correct ?
Regards
Dogan
Regards
Dogan
