Hi all... I need a bit of advice. I've been reading posts about how the glowplugs on a 220 cdi w210 chassis can be troublesome. I thought I would replace them anyway as the car has done 130,000 miles on the originals. I replaced three of them with absolutely no problems at all. I thought it was going too well. The plug at the rear makes a creaking noise when I try to undo it. I indone it approx 1/8 of a turn and decided to leave it for fear of it breaking off. I sprayed wd40 down in the bores in the morning and changed the plugs in the afternoon. Not sure if this plug needs more soaking or is just carboned up and not worth worrying about until it stops working. It works fine at the moment. It's just annoying me knowing I have one old plug in there. A friend suggested putting a little diesel down the plug bore as this is what most releasing agents are. What do you all think?
I'm about to change the drive belt tomorrow and worry that I might also have the sized alternator clutch problem. Has anyone changed this without removing the alternator?
