W210 Fan
http://search.autotrader.co.uk/es-u...CEDES-BENZ&model=&min_pr=&max_pr=&max_mileage
please rip to shreds so I can beat the guy down
Its over priced a bit
I had one offered to me for £6500 with the same spec and slightly lower milage. I would have bought it but I am £6500 short.....
im interested tell me more........
KLP could you give me a quick down on ADS, what it does etc,
ADS
Adaptive Damping System
The standard-specification AIRMATIC suspension system of the S-Class combines pneumatic suspension with an Adaptive Damping System (ADS), which adjusts the front and rear shock absorber forces to the current payload, the condition of the road surface and driving style. A steering angle sensor, three acceleration sensors on the car body, the ABS speed sensor and the brake pedal sensor constantly measure the lateral and longitudinal acceleration of the body. From this data, the ADS control unit calculates the optimal damper setting for each individual wheel and transmits the relevant signals with split-second speed to special valves on the gas-pressure shock absorbers. These valves are able to switch between four different damping characteristics. Using a selector on the instrument panel, the driver can also switch between a standard mode or a tauter, more sporty mode. This adjusts the thresholds at which the different damping characteristics are activated. In sporty mode, the firmest characteristic is selected earlier, while in comfort mode the softest characteristic remains activated for longer.
Slightly OT , but thats Maidenhead Railway Bridge in the background ...
My mates house is in the background of the photo ( rich boy )
The bridge was built by Brunel , and the government of the day said that no one could build a span that wide and flat out of brick , it would just never work ...
Brunel said ' I can ' and did so ...
When the government came to look at it , the wooden formers were still in place , and the government said ' It can't be safe , leave the formers in place !! '
Brunel did , and six months later , the government came to look at it again , and said ' Ok, maybe it will hold, take your formers down Mr Brunel !! '
Brunel then took them up onto the scaffolding to reveal to them that he had in fact dropped the formers 6 inches away from the brickwork since the very start and the bricks HAD been supporting themselves for all this time !!
It is still the widest , flattest brick built arch to this day !!
God bless Isambard Kingdom Brunel !!
Back on topic ....
Nice car !!
a more accurate description:
Back on topic ....
Nice car !!
It works very well normally - and the later car will have ADSII. The problem is overhauling the system when it wears out (and it will). It's very expensive - £5k to replace it all - so a sensible warranty may be order?
