Thank that is good.
I have a problem in that I have 30-40 good links with photo's what do I do with them
What a good write up. The spark plug one is also good.
You got any good ones on checking the electrics to the duo valves ? I could do with some listing voltages at the pins.
Many Thanks
I was under the impression that when the power connector is disconnected from the duo valve, this lets the water through. But when power is applied this stops the water from coming through.
Is this correct ?
The water flows when the solenoid is de-energised, they normally fail in the hot position.
OK....i havn't fully checked mine out but this is the problem:
On fully cold, the pipes (both of them) coming out of the duo valve is cold.
On full hot, the pipes are hot, so I get heating.
The problem is the in between settings do not appear to be working. Anything below full hot, the water goes cold.
Hence my reason for the voltages to the duo valve.....how are the valves controlled in the intermediate range ?
They are pulsed but it's about a 2 second interval so should be able to be metered with a DMM.
not easy with a DVM because of the gate time, you would see it on an analogue meter
